400 Sbc
Old 04-05-2010, 06:42 PM
  #1
edbrgolf
Member
JOURNEYMAN
Default 400 Sbc
Just wondering what would cause no end play on the crank.
edbrgolf is offline
Old 04-05-2010, 07:46 PM
  #2
zipper06
Thrust surface on the crankshaft worn. Also possible but not likely the rear main block faces worn and letting the rear main slide back and forth.
zipper06 is offline
Old 04-06-2010, 02:14 AM
  #3
johnracer
DYNO OPERATOR
Is this a new build?
johnracer is offline
Old 04-06-2010, 04:19 AM
  #4
curtisreed
curtisreed's Avatar
Zip,
Wouldn't that cause too much end play?
curtisreed is offline
Old 04-06-2010, 04:25 AM
  #5
wmeabates
Rear cap not alined to block,needs moved forward or backward.Bill.
wmeabates is offline
Old 04-06-2010, 07:47 AM
  #6
edbrgolf
Member
JOURNEYMAN
Yea its a new build with a new crank on a gm 817 block with clevite H series bearings.
edbrgolf is offline
Old 04-06-2010, 11:02 AM
  #7
oldandtired
oldandtired's Avatar
Did you "set" the rear main bearing before you torqued the rear cap down? You should bump the crank foward then backward before torquing. Dave
oldandtired is offline
Old 04-06-2010, 04:50 PM
  #8
zipper06
Zip,
ops: ops: , Crap i misread the post, i assumed he meant to much end play.
Oldandtired, is right if the cap is not doweled you have too smack the crank forward and backward before torquing the cap down. also they sell an over size rear main to solve the crank wear, it's possible you accidently got one of these in the main bearing set. If you have a set of calibers pull the rear main cap off and measure the the bearing width the check the crank thrust surfaces width.
zipper06 is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
