TORQUE SPECS
Old 03-26-2010, 11:28 AM
  #1
JEFF69Z28
DYNO OPERATOR
Default TORQUE SPECS
What should i torque the bolts to on my monte carlo front upper and lower control arms to?also what should the ball joints on the above be torqued to?
JEFF69Z28 is offline
Old 03-26-2010, 12:56 PM
  #2
FullTimeRacing
DYNO OPERATOR
I have never put a torque wrench on those type of parts.I hit the lowers with a impack and the uppers with a wrench,with the weight of the car on then tighten.also tighten the balljoints with a wrench.line up the hole for the kotter pin.
FullTimeRacing is offline
Old 03-27-2010, 04:58 AM
  #3
JEFF69Z28
DYNO OPERATOR
I PUT TUBULAR UPPER AND LOWERS ON.I SHOULD LOOSEN THE NUTS PUT THE TIRES BACK ON LOWER IT THEN RETIGHTEN.
THANKS FOR THE INFO.
Old 03-29-2010, 10:24 AM
  #4
FullTimeRacing
DYNO OPERATOR
yes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
