350 sbc using 4.0 stroke cranks
Old 08-05-2009, 11:10 AM
  #1
jreiley
Default 350 sbc using 4.0 stroke cranks
Winter project. Rebuild sbc. Any problems using a crank with a 4.00 inch stroke and 6" rods? Any machine work needed to be done on the block?
jreiley is offline
Old 08-05-2009, 11:46 AM
  #2
heshtesh
Member
MASTER JOURNEYMAN
I don't know if a 4" stroke crank will fit in a stock 350 block but if it doe's i'm thinking the block will be one scary looking piece. Seems to me you would have to grind a lot of material away to achive proper clearance.
heshtesh is offline
Old 08-05-2009, 12:01 PM
  #3
hink
EXPERT BUILDER
It might cost you a couple blocks if you hit water.
hink is offline
Old 08-05-2009, 12:02 PM
  #4
oldandtired
oldandtired's Avatar
x2. Even if you use a 2.000 rod, there is way too much material to grind away. When you get .050 clearance, how much block is left to hold back the oil presure or water? Enough to give me nightmares...
Dave
oldandtired is offline
Old 08-05-2009, 02:22 PM
  #5
jreiley
From what I understand, a sbc 400 stock crank will fit with some machining on the mains. Don't know if this is true. Just thought I'd mention it. There are a few crank vendors that sell the 350 crank with a 4" stroke. Maybe the cranks are for Dart blocks. Don't know.
jreiley is offline
Old 08-05-2009, 03:29 PM
  #6
FullTimeRacing
DYNO OPERATOR
the 350 main don't mean 350 block,You get most aftermarket in 350 mains.
Smaller main=less resistance.Right hink?,Thats what i've been told.
FullTimeRacing is offline
Old 08-05-2009, 03:36 PM
  #7
FullTimeRacing
DYNO OPERATOR
Default Re: 350 sbc using 4.0 stroke cranks
:?: Why do you want that long stroke with such a small piston?
you building a tow truck?
Old 08-06-2009, 07:02 AM
  #8
kwkracing
There are several people around here running 4" cranks in stock 350 blocks. i CAn aask but i believe they are pouring very little block filler in the bottom of the block, below the sand casting plugs and then grinding away.
kwkracing is offline
Old 08-06-2009, 09:36 PM
  #9
ashbros
use a 400 block with a 3.625 rod you'll love the big piston and little stroke
ashbros is offline
Old 08-06-2009, 10:27 PM
  #10
mytmouz
mytmouz's Avatar
If you run I beams no filler eeded, if H beams, then you will need some...
mytmouz is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
