Help with storing tips on my new engine?
#1
APPRENTICE
I just got my long block 540 And my car wont be ready for a year or so.The 540 is brand new.Any tips on storing this engine?Should I turn It once in a while to decompress the springs?Should I spray some type of lube in the cylinders to keep the rings from sticking?If so what lube do I use.What other things should I consider.Should I put oil in it and prime it once in a while?Any help will be great.Thanks in advance...Brian PS. This is a 540 long block with dart 355 cnc set up for blower app.
#2
SENIOR BUILDER
I'd pull the plugs, spray the cylinders down w/ some PB Blaster, loosen the rockers to take the pressure off the springs and tape up every orfice and bag it w/ a garbage bag.
When the time comes, dont forget to prelube it.
Good Luck
Craig
Good Luck
Craig
#4
#5
Member
MASTER JOURNEYMAN
not to dissagree with anybody but dont use pb blaster get your self some fogging spray or zep 45. i used pb blaster in a short block once and used every percausion and the pb actually stained my cyclinder bore and i had rust stain that i had to use clr on to remove.i even turned the motor over weekely on the stand had it bagged and all. since then i have used fogging oil spray or zep 45 spray it has teflon in it that stuff works great it puts a nice coating on things
