View Poll Results: any help on 75% 25% carbs
Voters: 4. You may not vote on this poll
new 75% -25% carbs
#1
SHOW GUEST
I was reading a add I receved from chuck Nuytten about a new carb he has out It uses 75% racing fuel and 25% alcohol ,claims to use the same heat plugs same fuel pump as racing fuel Has anyone tryed one of these or know someone who runs one ????? would like some feed back thanks :?
#2
There was a topic on one of the forums a few months back, seemed guy had more trouble then it was worth and took it back off.
IMO a good gas or alky carb would be much better.
#7
You could always try carb w/fuel and alcohol Injection at manifold (direct Injection). I do it with blowers quite a bit.
If your looking to reduce static pressure just throw a 100 shot on a carb with fuel.
