external oil / vacuum pump
#1
SENIOR BUILDER
looking at installing an external oil pump with vacuum pump, but I need to reverse the pump so it turns counter clockwise, no room to mount it to the back, I want to keep it a wet system, just like the idea of adjustable oil pressure and a vac pump all in one. and pros and cons out there ?
#3
I had an alcohol injected 615 I used a star vacuum system and a wet sump oiling system with a 3 qt. accumulator. Couldn't be more pleased with the set up.
Provide an email address thru rj and I will send pic of my set up to you.
