fuel pump problems
EXPERT BUILDER
efi 92 gmc 1500 ext cab short bed 350 havin real bad problems with a lag when a floor it it feels like its just not gettin enough fuel and its the stock pump and im at 152k i changed the filter to see if that was the problem but no such luck so idk all other filters are new along with the oil so i have no clue :cry:
#14
DYNO OPERATOR
Back a couple of posts, usually when the fuel pump on those trucks goes bad, they just quit, they don't slowly die and if you ever need to change it, it's easier to pull the bed off than to drop the tank.
Probably just need a good tune up, ei cap,rotor,wires and plugs. Have you tried to run it with out the air filter and see what happens? maybe the cam going flat, I think that was a problem on those engines also.
#17
ANY SERVICE ENGINE LIGHT?? IF SO AUTO ZONE OR ADVANCED AUTO WILL CHECK IT IF ITS THROWING A CODE... I HAVE SEEN A FEW CATALYTIC CONVERTERS PLUGGED BEFORE... PULL THE PLUGS AND SEE WHAT THEY LOOK LIKE..
#18
EXPERT BUILDER
haha thanks but no cats 3 in strait pipe down to single chambered race series flowmasters and they pullled up egr so a just took that off the motor and blocked it off but that was a long time ago
