Oil pressure
12-28-2009, 01:18 PM
Glad you found the problem. Now you can sleep better at night and stop pullin' your hair out. At least the hair you have left. :shock: :lol:
12-28-2009, 01:34 PM
I knew it had to be leaking somewhere , too bad you can't drill it , tap it and plug it...glad you found it,
12-28-2009, 06:48 PM
The next question is;... what caused it to crack at that location ?
or was it a casting flaw ?
12-28-2009, 07:30 PM
Yes it is a casting flaw, when new bearings, gaskets were installed, everything sealed tight where oil pressure was up for a few minutes i guess it finally blew out and started leaking, could have been seeping all along :!: :!: Have new block building now :!:
''JUST MY TWO CENT'S WORTH''
01-02-2010, 08:17 PM
Got new engine together, 60 psi @ cold idle, 38 psi hot idle. 205 degrees.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
