bbc motor smoking
#42
Originally Posted by BEAST477
Oops, just reread the post. Smoke changed from white to blue.
Who knows... Maybe it is.
#43
#44
OBGMC:
No synthetic oil on break-in w/ moly ring's.... good to know, did not know that.
I was told that break-in on Moly Ring's should be gentle for seating purpose's.... is that not true??? Just go out & run the crap out of it??
#45
Originally Posted by Rigsby
OBGMC:
#46
Years ago , the rings were not as good and it took time to break them in.
With the newer moly rings, I break it in like its going to be run. The rings seat quickly and the rest of the engine doesn't need any breakin if you run a roller cam. Flat tappets need a breakin by keeping the rpms up to prevent flattening a lobe. (Unless that has changed).
#47
If the smoke does not clear up, and its not black smoke,, you should probly tear the motor down and check it, because something might not be right with the clearances and could cause some high dollar damage.. i hope it clears up, good luck...
