dodge 440 getting hot
#21
Originally Posted by roadkill2
C'mon guys . . there's at least two, and probably three threads up here that deal with overheating, and they all "boil" down to a couple of things, either the water isn't in the radiator long enough or the radiator isn't big enough. A third might be not getting enough air through it in the right places.
On th' Mopar Motor Home. If it works good at 55 but heats at anything over, it's one of two of the above . . It ain't rocket science.
#24
EXPERT BUILDER
I was told by the owner that this 440 came out of a 78 Monaco police car. This may be true cause it does have h.p. Stamped on top of block. I know that coolant is not staying in radiator long enough. So my question is do I drop back to a 6 blade pump and or stock radiator for a 78 cop car? Hmmmm.
#25
Originally Posted by kbartley
Yep, steel fan 1 1/4" space between fan & radiator
Do this experiment, yank off the hood and see if you get the same results.
We're gonna solve this problem yet.....
I pull with my '77 Dodge 24' MH 440/727 no AC but with a trans cooler. Has gotten quite warm towing over some bigger hills. My brother checked it out one day and mentioned my vac advance hose was plugged into the wrong inlet on the carb. Hence no timing advance and the engine was working less efficiently and heating up. Original complaint was no power up hills. It runs cooler with MOpower !
#26
The Pursuit vehicles had huge radiators, generally, because they were designed to sit, idling, with a load on the accessory drive from the A/C, and the 185-200 amp alternators, and also for running at high speeds for long periods.
The RV's on the other hand were designed to be tucked back into a hot doghouse and run at optimum torque generating speeds, which in most 383/440's is around 2800-3200 rpm and about . . Yeah, 55 mph . . So for that turd you needed to put a lot of water through a fairly large frontal area radiator . . If you have one of those and a little radiator, you're probably gonna have heating problems . .
#27
EXPERT BUILDER
We'll the guy at champion radiators told him in the beginning that the 4row would be plenty. So when that didn't work they told him that was a bad design & sent him a 2 row. Now both radiators only have a 22" wide core barely 18" tall. Thinking about going with the radiator that's supposed to be in front of that engine. It's got a core that's 27.5" wide. Then there's the shroud issue.. Got to find that.
I tell ya, this thing is taking up valuable shop space. Uuuuggghhhh!
#28
EXPERT BUILDER
I really do think at this point he would sell it. Or I might ;-) butt it's painted up like the general lee. Which is kinda interesting because he is way tooo young to know the show. We both do agree that this car is cursed. I started fixing things on this car last summer. Trans, wiring, centerlink under oilpan somebody ground off half of the material to clear pan. Reworked the 440 over the winter & put it in. Might have 50 miles on it. Now this. Ahhh nevermore me im just venting. I know, I know, wrong area of the forum
#29
Vent away Man ! We ALL have had dealings with cars like this ! GAAARENTEED !
At this point I'm saying the biggest aluminum radiator you can stuff in there. Speedway has a lot of universal units available. 31" X 19" - $140 to $400
