BUBBLE GUM WELDS can they fixed
#21
Originally Posted by outlaw256
Originally Posted by curtisreed
I have done quite a bit of TIG welding so here is my opinion on a couple of things asked here.
I believe the issue would be if the whole thing were MIG welded and then ground down / or not, then TIG welded over because the TIG is such a smaller weld bead that you would not get weld penetration to the base metal only into the weld already there.
I think because moly tubing is so much more prevalent than in the old days. Tig does provide a smaller nicer looking weld in the right hands and MIG is not recommended on moly even though it can be done. It is a little harder to tell the penetration of a MIG weld also.
Curtis
Originally Posted by todd8525
Not sure but i was told u are not suppose to TIG over a MIG weld?Yes /No or is this a myth.
dont have a tig welder here but i gotta hell of a big mig. we have built frames amd everything else you can think of. why is tig now the only way to go when mig was it before. someone with a gun in his hand that knows how to weld can weld a frame up just as good and strong as tig welded.imho...
Curtis
You are absolutely right about the strength of MIG welds being safe though.
Curtis
#22
thanks man now i feel alot better. ive been told that tig was stronger and all this other bs.never could understand how it could be stronger welding is welding PERIOD.as long as you can penatrate the metal and pool it together its there.now im going out a roll a car, going to retest my welding...lol not really am already crippled up...
#23
The reason that Tig welding is mandated on Cromoly, is that it doesn't cause embritment at the adjoining surface of the weld. Both stick and mig welding causes the metal close to the weld too get harder and fractures easier on any 4300 series steel. We do lot's of welding in the Plastic injection mold building business and we have everything from mig to laser welding equipment. We weld on repairing molds from every thing from 4340 mat'l to tool steel. Most Molds are built using 4340 mat'l and heat treated to 42/45 Rockwell hardness, same like rearend gears, except the pro gears which uses 9310 mat'l, which is the same except has more nickel mat'l in it.
The mig weld is absolutly as strong as tig, but it causes the embritment on cromoly. The mild steel chassis or roll cages do not have the embritment factor that cromoly doe's.
I can assure that every inch of weld on my roll cage in my Malibu is tig welded, because it's cromoly and it's only a 6.50 car in the 1/8 mi.
#24
thanks big time zip!!! im runnin a copy of your post off and going to hang it in the shop and dare anyone to argue with my hero!!!lol i was at one time a certifed welder,like back in the late 70s.lol long time ago i know. thats the answer i wanted right there.im not up on the material aspect as i should be. but i will be !!
#25
#26
AAAAHHH... GREAT info, Zip ! Man would i ever like to take a tour through your work place ! I'm always fascinated about manufacturing processes and the peripheral skills supporting them.
#27
We have one of the best equipped shops in the South, with between 3 and 4 mil. in CNC equipment 4 and 5 axis milling machines CNC lathes, wire burners and elox machines. We can punch a 1/16" hole thru an 8" pice of 60 rockwell steel in less than 10 min. and it will straight within .002 at the exit point. We don't work in thousands we work in tenths of .001. We do a lot of work for the medical industry and repair broken molds that some times weigh as much as 5,000 when they are all together. We're small only 12 employees but precise, and everything is CNC.
#28
SHOW GUEST
Like Curtis said ^^^^^ "It is a little harder to tell the penetration of a MIG weld also".
Uhhhhhh . . . . , I would NEVER trust a shallow penetration MIG weld on any Suspension or Roll Cage weld, PERIOD.
Let the T-shirt welder guys on TV use it on sheet metal, should not get anybody very hurt.
I still have several clients that will not allow MIG welding on any of their pressure vessels due to this very fact.
44 years of this stuff.
Take care, K
Take care, K
#29
Off the subject, but Zip mentioned Winburg Crankshafts. If you have ever held one in your hands you will agree with me that they are a stunning piece of art. It's almost a sin to hide one inside an oil pan!
#30
Take care, K
Take care, K
