rpm not changing
Old 01-22-2011, 07:20 AM
  #21
fast75vega
Originally Posted by itsabird
I am starting to think along the same line as fastvega, fuel problem, a little lean, did you retune your carb after the port work, and what was the 1/4 mph on that pass?
i thinking either not enough air(dirty air filter) which is making it run rich or its starving for fuel on the top end... i've had both happen to me and it sounds the same :wink:
fast75vega is offline
Old 01-24-2011, 04:49 AM
  #22
smokinsmallblock
APPRENTICE
i have a 1050 carb. on it. 92 jet square. plugs stay black. sometimes i run wit no hood on so i think its gettin enough air
smokinsmallblock is offline
Old 01-24-2011, 05:00 AM
  #23
fast75vega
if the plugs are staying black..... def sounds like ur running rich then :wink:
either too much fuel or not enough air.......try running it with out the air cleaner for a pass or two and see what it does :wink:
Old 01-24-2011, 05:27 AM
  #24
smokinsmallblock
APPRENTICE
i dont have an air cleaner on it at all. i have jetted it down to 90's but no change
Old 01-24-2011, 08:09 AM
  #25
itsabird
Sorry just getting back, cable has been down. it could be rich at idle and the main circuit still lean. what size idle air bleeds, also high speed bleeds, is it a 3 or 2 curcuit carb?
itsabird is offline
Old 01-26-2011, 05:07 AM
  #26
smokinsmallblock
APPRENTICE
i dont know the answer to the carb question, but i have took the 1050carb off an put a 950 carb on it and it response alot better an sounds crisper. but the 60ft an et stay the same with both carbs
Old 01-26-2011, 05:27 AM
  #27
shawnp
What ignition box are you running? I had this happen with a brand new, out of the box 7al3 from MSD.
shawnp is offline
Old 01-26-2011, 05:29 AM
  #28
smokinsmallblock
APPRENTICE
i have an 6al
Old 01-26-2011, 05:31 AM
  #29
fast75vega
i would figure that your 60' would be.... but did you notice a diff. on the big end :?
Old 01-26-2011, 07:35 AM
  #30
shawnp
So this has been a combo that has been together and worked fine with no previous problems? If so, what have you changed besides the gear?
shawnp is offline
