TIMING ? AGAIN
#21
DYNO OPERATOR
Originally Posted by Tod74
Originally Posted by JEFF69Z28
Originally Posted by cepx111
I'd re-gap the plugs to no wider than .032 and try again.
JMO>Cp
JMO>Cp
#23
DYNO OPERATOR
Originally Posted by wmeabates
Jeff,Did you set your timing pointer to your damper using a piston stop? Bill.
#24
Member
JUNIOR BUILDER
Not that I know of But I made one by cutting the guts out of a spark plug & welding a piece of steel in that protruded into the cylinder area thereby not allowing the engine to rotate past the bit sticking in. Obviously you will need to be able to turn the engine over gently so as not to bend it.
#27
JMO>Cp
JMO>Cp
#29
DYNO OPERATOR
You can use a threaded positive stop in the spark plug hole to find true TDC. BUT BEFORE YOU USE IT, take the rockers off that cylinder or you can bend the valves.
If your balancer is marked in degrees before TDC, screw the positive stop in to stop at 30 degrees. Then measure carefully the distance from zero to 30 degrees and put a mark on the other side of zero at that measurement. Rotate the engine backward slowly till it is against the the positive stop again. If it stops at 30 degrees, your timing pointer is correct. If not, move the pointer until it is equal degrees on both sides of the positive stop.
If you only have a zero mark on your pointer, just pick any measurement around 1 inch and put that on both sides of your zero mark and move your pointer until the measurement is equal on both sides of mark.
Morroso, Manley, MR Gasket, Comp Cams and others make an aluminum threaded positive stop.
#30
DYNO OPERATOR
WHEN THE #1 PISTON WAS AT TDC THE ROTOR IS POINTING AT THE NUMBER 6 CYLINDER AND THE #1 PLUG WIRE IS IN THAT AREA ON THE CAP SHOULD I PUT MY TIMING LIGHT ON THAT WIRE?OR SHOULD I TAKE THE DIST.OUT AND HAVE THE ROTOR POINTING AT NUMBER ONE.BOY AM I CONFUSED!
