cooling in the pits
#24
Originally Posted by us7race
That cooling pump also needs the ATI Supercase :shock:
#26
I think its ATI who makes the pump you are looking for but its $800.00
#27
SHOW GUEST
Plumb the lines to the side of the pan using some quick release fittings with one-way valves from a hydraulic shop, use an old Melling oil pump with a drill attached to it and run the trans fluid through a coil of copper line sitting in an ice box - cools a race TH400 in 10 minutes to completely cold....and you can also keep the beer cold if the ice box is big enough....
#28
We use Weldon high temp pumps for our differential cooling system. The model 9200 is what you want along with a cooler from Summit or Jegs or.....
http://www.weldonracing.com/product/..._Oil_Pump.html
On sale here;
http://www.srmotorsports.com/Weldon_Fuel_Pumps.html
Cooler with fan here;
http://www.jegs.com/p/Perma-Cool/744433/10002/-1
On sale here;
#29
EXPERT BUILDER
I think it may help but I think the real heat is in the converter.
