welders
#21
Member
JUNIOR BUILDER
I am not sure on the models you are speaking of, but on various welders I have used, I have found the bigger welders smoother to weld with
It may be different on the model you are talking about, but it does seem the bigger welders make a nicer job on smaller welds
Years ago I had a 225 Lincoln stick welder, then bought a large 250 amp Miller. Laugh if you like, but it welded thin materials quite well. I have a scratch start TIG for it which is nice, but not as nice as the TIG we have at work(foot pedal)
I have a 220 V MIG as well. Bigger MIG s are easier to use than it
For me bigger welders seem to be easier to work with, so I would buy as big a unit as I can afford(as $$ as I could afford)
I will be buying a foot pedal TIG in the near future
#23
SHOW GUEST
Hello guys, Here is my opinion on welders. Buy a good quality ( I use Miller and lincoln ) name brand, if you need to resell it you'll get most of your money back. Look on ebay for a tig foot pedal machine and you won't see many millers or Lincoln's.
On the 110 mig, a Miller or Lincoln will work great on thin carbon steel, a little trick for thicker wall/steel full pen welds would be to grind a bevel and leave a gap the width of your wire dia. This will help burn all the way through. A 220 mig welder should be used here , but it can be done. Body shop welding, like panels and supports can be done with 110's but most good shops have 220's . So spend the money on a good name brand, it'll save you in the long run.
#25
SHOW GUEST
Well for what its worth,I am a master welder,20 yrs experence.With proper beveling and proper heat and wire settings you can wld up a cage with 110v welders.You have to pay close attention to duty cycle.Over heating welder causes loss of penetration and hurts welder.Also make sure you have a dedicated circuit with proper braker.I welded at a couple dirt tracks with there fluxcore lincoln and never had any failures.220v is the best way to go and a minimum of 180 amps.
#27
I agree with rdecker - use a dedicated power supply for a 110 unit. I have a Lincoln and it does an excellent job.
Never ( and I mean never) use an extension cord if you are welding somthing that your life will depend on.
