Carb Size - BBC
Old 02-01-2008, 09:57 AM
  #21
SPEEDNEEDS1
SENIOR BUILDER
I will call and see if he has an idea
SPEEDNEEDS1 is offline
Old 02-01-2008, 11:33 AM
  #22
hammertime
Call APD also .. both Pro System and APD have very good gas setups.
www.apdracing.com
hammertime is offline
Old 02-01-2008, 08:39 PM
  #23
jmarksdragster
jmarksdragster's Avatar
Default Re: carb
Originally Posted by lanham
It had a 1050 Quickfuel carb, was perfectly tuned the car ran 5.40s, then switched to the 1200 pro systems carb and after that it ran in the 30s with only a carb swap.I am not trying to sell their carb,this is just the good experiences i have seen with pro systems.
Is it possible the added CFM made the car go quicker?
My take is this, the largest carb that will CORRECTLY meter fuel on the intended car/engine/ RPM range will run the fastest ET. Not to take away from any carb rebuilder, they make changes to correct metering issues over the entire operating range of the carb. This will help on throttle stop cars and footbrake cars. On a wide open/transbrake type car, I think the advantage of a "Professional Built" carb over a stock, unmodified carb is diminished to less than a tenth with flow rates being equal and correct jetting for the app. The 9375 or 9377 Dominators (1050 or 1150) would work fine for your car if you take the time to get the jetting correct. If you have money burning a hole or don't want to set it up yourself, any of the above are fine, another is BLP carbs. Just remember, you still may have to change jets on anyones carbs to match your combo.
jmarksdragster is offline
Old 02-04-2008, 11:40 PM
  #24
cepx111
Originally Posted by SPEEDNEEDS1
I may also need a little help, I have a 468 (4.310x4.000) Edelbrock square port heads, 2.25-1.90 valves, 13.3 comp, .722-.722 lunati cam, all in a 3500lbs 66 Chevelle, 400 turbo, 5500ati, and a 5.38 gear....What do I need for carb. I have a 830hp and it ran good on my last 468 but with much less compression?????????? I also run 1/8 mile ONLY (5.38)
A Holley 1050 dominator is what I would recomend but most will say they are junk out of the box, but I beg to differ, I have had excellent results with them just playing around with the jetting to the motor's liking and consistent E.T."S and didnt spend a grand or more in the process either.
JMO ><CHarles
cepx111 is offline
Old 02-24-2008, 02:53 PM
  #25
farrigno
JOURNEYMAN
Default carb size
since were on the subject of carbs what is everybody's opinion/experience on my combo for carb size?; 565 bbc,15-1 comp,bmf350-heads,bullet roller808/775 282-in/294-ex,have a victor454-r-with a box stock 1050/8896 hp-model,car is a 3500 pound chevelle 10-inch tire t-brake,probably see a max of 7800-8000 max trap rpm with a 76-7800 shift point, on a n/a deal,any help would be appreciated.
farrigno is offline
Old 02-24-2008, 02:59 PM
  #26
topsportsman1
Administrator
For that 565 and RPM's your turning,you'd need a 1400 to 1450 cfm carb
__________________
There Is 1 Thing Better Than Cubic Inches,,,More Of Them
topsportsman1 is offline
Old 02-24-2008, 03:21 PM
  #27
hammertime
Default Re: carb size
1150 Alky Carb
1250 gas
www.apdracing.com
I had them redo a 1150 on a similar 565 and it picked up .15 after they were done.
Old 02-26-2008, 09:16 PM
  #28
procitation
Member
JUNIOR BUILDER
Default Cubic Carbs
Originally Posted by scuncio
Look into Dale Cubic @ CFM carbs, He makes a real nice carb.
We run only Dale Cubic Carbs. Definetly recommended!. Dale is a very seasoned carb builder. He has built carbs for some of NHRA prostocks top contenders. He is also a nice guy, easy to work with, and attentive to questions. I learned tons of info from him 8)
procitation is offline
Old 03-01-2008, 07:38 AM
  #29
topsportsman1
Administrator
Give Patrick a call he'll get you fixed up
http://www.pro-system.com/
__________________
Old 03-01-2008, 12:49 PM
  #30
Tod74
RON'S TERMINATOR !! Alchohol injection. They have I think 3 different sizes of throttle body.
Tod74 is offline
