carb spacers
#21
SENIOR BUILDER
I have a 468 edelbrock 315 square port heads, .722-.722 roller cam, 13.3 compression. I have a few options of a intake for this engine,what do you all think I should go with. 4150 series on gas????
#22
what do you guys think about those funnel shaped 2 inch spacers that adapt a dominator onto a 4150 intake? I have a 454-r made for a 4150 but use the adaptor to mount the dominator. Was wondering if I needed to change it...looks like the funnel would help pick up the air velocity.
#23
Pro Products intake IMO would be great for this combo. I've used these intakes they are cheap and castings do need some touch up work but they are proven and work good.
#24
#25
Do you think maybe the victor junior was just a better manifold for your motor or do you think it was removing the spacer that helped? I was thinking a Super Victor would be good on my 540 but I only wind it to 7000 so didn't want to go too big with the intake.
#26
#27
i switched to a 454r from TEAM G on my 511CI..but i also had plentum work done ( shortening the two front runners etc..) also had the ports gasket matched etc...very noticable difference in the pedal..can't say how much it picked up the car cause i can't keep the front wheels on the ground without the wheelie bars on car...lol :shock: ....the wheelie bars are now bolted on and ready for next trip.
i would suggest getting the ports gasket matched at minimum as i would suggest with any intake..
Brian
Brian
__________________
Bjuice..
"I'M YOUR HUCKLEBERRY ! "
Bjuice..
#28
In 1996 I sent my 4150 Dart intake to Shafirof to be ported and fitted for a dominator for my 572 . When I received it it had the adapter, I freaked. Anyway I was told to send it back and they would cut a big hole in the top to direct mount the 4500 carb and lose power. It works for us( I think) but this is all I ran. One thing for sure, there is extensive port work on the adapter and the top of the intake where they are blended together, thats 11 yrs ago, and now I see a lot of others doing it to,(Reher Morrison) funnel ram for one, good luck.
#29
Originally Posted by prostreethauling
:? I have a 454 .030 over running 11.7:1 compression .660 /.666 solid roller comp cam , pro 1 345 heads , victor jr. 454r intake, 850 carb reworked by pro systems with a 1" open spacer . The torque is low do to the big heads but I want to keep them and upgrade to a 540 someday but need to make them work on my 454 for now. Should I not run a spacer or run a 4 hole spacer like a wilson taper spacer and are they worth the money. Thanks.
