Holley Squirter Check Vales sticking, Alcohol
Old 06-11-2014, 12:40 PM
jmarksdragster
jmarksdragster's Avatar
You might try a stainless check ball the same diameter as the check valve, and cut the same diameter as the ball off the length of the check valve. Put the check ball in first, put the old valve on top for weight. Don't ditch the body, if there is an issue with the seat that can be replaced as well. You can get them from BLP or Quick Fuel, those bodies are the same that Quick Fuel uses.
jmarksdragster is offline
Old 07-20-2014, 11:53 AM
oneowner73
Member
JOURNEYMAN
thanks for the reply Mark. Sorry it took me so long to respond. Good info that I will try. Will keep working with this main body but i think I could use a little more cfm and was looking at some of BLP's main bodies. Thanks again, Brian
oneowner73 is offline
Old 08-11-2014, 04:18 PM
  #13
oneowner73
Member
JOURNEYMAN
Mark, I went through my junk and found 1 check ball the right size at .156. Had others too big and too small at .187 and .123. Where would I have to look to find another .156 check ball? Brian
Old 08-12-2014, 04:13 AM
  #14
curtisreed
curtisreed's Avatar
You can get them from McMaster-Carr online. Or if you have a bearing sales place close by they usually have them.
Curtis
curtisreed is offline
Old 08-15-2014, 05:14 PM
  #15
oneowner73
Member
JOURNEYMAN
Thank You Curtis. I will give them a try. Brian
Old 08-15-2014, 06:19 PM
  #16
oneowner73
Member
JOURNEYMAN
Check balls ordered. Had to order a quantity of 100 so I will have several lifetimes of this item. Was going to go to carb shops in Indy but buying 100 was cheaper than the gas. Thanks again and I will need that company in the future. Brian
Old 03-16-2015, 06:42 PM
  #17
oneowner73
Member
JOURNEYMAN
jmarksdragster, do you have any time to work on a carb for me?
Old 03-17-2015, 08:30 AM
  #18
curtisreed
curtisreed's Avatar
I don't know how often he comes over here since the change and drop off of users. You might be better off going to the site that is in his signature and asking him there.
Curtis
Old 03-17-2015, 05:21 PM
  #19
oneowner73
Member
JOURNEYMAN
Thanks for the info Curtis.
Brian
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
