oil pressure drops at topend of the track
Old 04-08-2013, 11:48 AM
curtisreed
curtisreed's Avatar
The fluctuation on the brakes is pretty typical. I run an oil accumulator for that very reason. I have ran 3 different pans and have had oil control problems with all 3. I didn't want to have to be concerned if I got on the brakes hard. David is right about the oil running away from the pick up.
You added that you didn't notice it until you lifted getting the car straightened out. Sounds like maybe the oil was moving away from the pick up then. Did you see the pressure drop under power, going straight, at the finish line on another pass?
curtisreed is offline
Old 04-08-2013, 12:09 PM
Swiley383
Swiley383's Avatar
Yes, I did I started watching it going down track the pressure was getting down to around 20 to 25 psi on every pass. I beleive I made 5 more passes and it droped every time.
Swiley383 is offline
Old 04-08-2013, 02:17 PM
  #13
markdunlap
DYNO OPERATOR
Default oil pressure drop
Is the oil pick up welded to the pump and does it have a brace from the end of the pick up to the pump?
Maybe it fell off the pump.
markdunlap is offline
Old 04-08-2013, 06:25 PM
  #14
TheYellaBrick
TheYellaBrick's Avatar
Or in the process of falling off and suckin' air/oil. Looks like dropping the pan might be in the future.
Electrical or mechanical gauge/sender ?
TheYellaBrick is offline
Old 04-09-2013, 02:39 AM
  #15
itsabird
Sounds like oil pan issue, trap door, or nothing to keep the oil from running up the back of the pan on acc..
itsabird is offline
Old 04-09-2013, 04:59 AM
  #16
Swiley383
Swiley383's Avatar
Its a mechanical gauge. The pick up has a bracket on it that bolts to the pump housing I can't remeber if I welded it also.
Old 04-09-2013, 07:01 AM
  #17
oldandtired
oldandtired's Avatar
Default Re: oil pressure drop
A very real possibility.
oldandtired is offline
Old 04-09-2013, 07:39 AM
  #18
Swiley383
Swiley383's Avatar
sounds like I need to pull the pan and check and I may try anther pan as well can you guys recomend a a good pan with a kick out sump an a 7 or 8qt capacity
Old 04-09-2013, 06:33 PM
  #19
zipper06
Moroso with built in screen wiper.
zipper06 is offline
Old 04-10-2013, 10:20 AM
  #20
Swiley383
Swiley383's Avatar
I am also thinking of changing the pump while at it what is your thoughts on this? Should I wait and see if the pan fixes the problem and would switching from 20W50 VR1 to 10W30 make any difference? I know the folks on here have more experence and knowledge than I do. I just want to make sure I cover everything.
