fuel pressure and filter
Old 12-28-2012, 05:27 PM
hammertime
Originally Posted by TheRabbit
Try running one with the filter and then take the element out, you may be shocked.
I never run one after the pump, to much restriction.
That's actually backward. Pump is gravity fed with pressure on the out side.
I don't run one before the pump. :wink:
A/B test one with the filter before and after the pump, report back with the egt and o2 readings I've seen it first hand (atleast with a 8an earls in line filters after pump) they can cause a bit of restriction.
I quit running filters and use a outterwears filter when pumping fuel now.
hammertime is offline
Old 12-28-2012, 05:41 PM
TheRabbit
TheRabbit's Avatar
NO WAY I'm running a 8an filter.
The BG filter is screwed directly into the Areomotive pump on mine.
Feeding this with an 8 aint' gonna happen. lol
36N
32N
28N
TheRabbit is offline
Old 12-29-2012, 06:15 AM
  #13
hammertime
8 an from the pump is common on just about any fuel log application.
ps ... that looks cool as hell !!
Old 12-29-2012, 09:13 AM
  #14
wazup
EXPERT BUILDER
Dam Rabbit i think you need a 20an to feed all that lol. Thats a bad a$$ looking setup you got. Love it.
wazup is offline
Old 05-03-2013, 11:44 PM
  #15
reno2486
SHOW GUEST
u see Aeromotive, they suggest associate degree alcohol one hundred fifty steel mesh filter before the pump and a paper forty mesh filter before the carb. i assume everybody did not move to an equivalent filter faculty in school.
I simply use the one hundred fifty mesh before the pump. Not an excessive amount of restriction, nonetheless keeps out any larger debri from reaching to the needle and seat on a carb.
2013 MERCEDES BENZ SL-CLASS
reno2486 is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
