BBC Aftermarket Blocks
EXPERT BUILDER
Originally Posted by zipper06
Has anyone seen or looked at the BMP alum. blk that Naylor in SC is selling for around $3400.00.
I've owned and run KB and Donavan, both with water and solid.
Price is good but i don't know if the blk is.
Just curious
Zip
Just curious
Zip
#13
APPRENTICE
I work for World. If you need anything, please don't hesitate to call.
If you want an honest opinion, CNC BLOCKS, HINK, CARL, whatever he is now is not the place to look. He is selective in his information and sometimes straight out inaccurate.
Rather than drone on here's a link:
www.cncblockne.com
We were the first ones to make aftermarket BBC blocks. Our MERLIN PRO was deemed illegal as an unfair advantage by the rules committee so we discontinued it.
We make a damn fine product no matter what CNCBLOCKS wants to make up.
My direct phone number is 201-403-3699 if you want to call me.
www.cncblockne.com
#14
APPRENTICE
Just curious
Zip
Just curious
Zip
Bill Mitchell Products - BMP
http://www.theengineshop.com
#15
APPRENTICE
Just curious
Zip
Just curious
Zip
Our aluminum blocks are cast in the same foundry as Lamborghini, Ferrari, Bently, and Penske racing. I'd be hard pressed to say that those companies would use junk.
THey are machined in North America by a leading block house. The fit and finish is far and above what you're accustomed to seeing and require less machining than the competitors. Anyone that has seen our product side by side with any other competitor says it looks light years ahead.
We have better oiling capabilities than anyone on the market. We keep the oil off the cam, and down on the mains. We have better cooling that our competitors.
I don't know where you're located, but you're invited any time to swing by if you want to take a look at one.
Those who have seen ours side by side, will tell you our fit, finish, and design is superior. Those who haven't will have opinions, but no facts.
#16
APPRENTICE
Here's a link to an aluminum Ford block with big pictures.
http://www.yellowbullet.com/forum/sh...ighlight=world
Here's some of our FORD heads:
Hope that helps.
Hope that helps.
#17
Just curious
Zip
Just curious
Zip
As i said i saw the ad at Naylor engines in SC. He's advertising 1000 plus HP, complete engine for $10,500.00, that's pretty reasonable and hard to beat at that price, don't know if he has a happy dyno or the #'s are real. It doesn't say what BLK or heads but it's obviously an iron BLK. The reason i ask is that my car is a lead sled at 3250 lbs. with SM/BLK and would perfer to use an alum blk. if i go B/BLK. also can the blks and heads be bought factory direct?
I should add that's i've been a machinest for over 50 yrs. the last 35 as a CNC programmer/machinest. I have access about $5 mil. CNC equipment available to me from the Plastics injection mold building shop that i recently retired from, including 2 5 axis milling machines, so i'm no stranger to how to check something out, even at in my home shop i can check most evety thing on a blk. I do build a few engines for friends each yr.
Below are the ads i'm referring too.
http://www.racingjunk.com/Drag-Racin...D-ALL-NEW.html
http://www.racingjunk.com/Blocks/252...UM-BLOCKS.html
#18
EXPERT BUILDER
www.cncblockne.com
www.cncblockne.com
Thanks for posting your number !!!!!
#19
SENIOR BUILDER
Originally Posted by hink
with all this BS you are spreading about me jesup I smell a lwasuit coming!!!
#20
EXPERT BUILDER
