Launch Tuning
Zip,it sounds like the car is going left when the track is good,by limiting or slowing the travel of the left front it will let the right front load the left better.Once the wheels are up that part is over.Still might be in the tires though.Bill.
SHOW GUEST
right about the age of the slicks but they were stored properly and have very few runs on them but it still could be. The problem is not carrying the LF the real issue is that on a clean hot slick track it goes straight.... later on when the track cools off and rubbers up it pulls hard to the left, too much to make it consistent. I have to steer it hard and lose about .08 to hold it off of the center line or wall. it seems to yank left and right up about equal amounts, except the better the track gets it jumps to left on launch.
Thanks for all the input!
#15
SHOW GUEST
all suspension points seem tight, I have found that I had about 5/8 more travel in the LF before it comes off the ground than the RF ( I have evened that out with a travel adjuster). I will either have to shim or spring rubber the LR spring, they are stock type coils.
#19
SHOW GUEST
Bill, that is exactly what i'm thinking lol, but to change it will require cutting and re welding the frame mount bracket.... which I already have made the replacement pieces to do that but since it worked so good early I was hoping to tune around it.
Mark, I'm in on new slicks. These just work really well early so I'm trying to get as much out of them as I can since they are like new.
#20
Ok Dirt now I got you.When you said non adj.I thought you just did not have the link to adj.them on the car without disconecting them.I had a ladder bar car with stock coils&shocks that worked good with 1/2 inch right side preload,it that tells you anything.Bill.
