do i need a mag?
SENIOR BUILDER
Originally Posted by maxpower671
Originally Posted by ccperf721p
I run a 7AL2 with a pro power coil on a 15:1 alky injected 434. On a couple of occasions it has fired a 15% tip of the can without issues.
#13
SENIOR BUILDER
#15
SENIOR BUILDER
Originally Posted by zipper06
I also run Autolite 3923 in my small blk. they are exteded tip, don't know if they will work with a b/blk, i have to index them with my 14 to 1 pistons, just a suggestion.
#16
I'd index them and roll the engine over by hand and see if they hit, if not id give them a try.
#17
SENIOR BUILDER
the standard plug reach is .460" and is flush with the chamber. do i need to get the tip into the combustion chamber as far as possible? change up to .750" reach and extended tip if it will fit?
which way do i index the ground strap? did that many many years ago with a small block dodge, made no difference in that instance.
#18
Wooh !!, you can't use a .750 reach plug if you are inside the chamber @ .460, but you can still use and extended tip plug, but a short reach. This now becomes a whole new ball game. I don't personally have any heads that use the short reach heads, so i'll leave it to someone who does.
#19
#20
SENIOR BUILDER
