blower motor
SHOW GUEST
imm runnign 2.5ton rockwell axles so breaking axles is not a problem haha. But all the setups you guys are running sound really reasonable! Im not running for a timeslip like you guys are so being on or off 11hp wont hurt me too much so if i could push high 1000 or low 1100s i would still be really happy so im not on a strict motor setup! i will be running a 454 block and ike i said it will be a race truck so it barely gets run and wen it does its for a maximum of 5 minutes! so any other suggestions is greatly appreciated!
EXPERT BUILDER
Originally Posted by gyellow88
so what rotating assembly do you guys think i should go with? and the cam sepcs i wont know for a little bit cause i wanted to get my head setup first! And blown injected 540...you made that much power on just 11pounds?? i was thinking i would have to run in upwards of 20plus pounds ??? Thank you guys for the responses i greatly appreciate it
