Anyone build headers in North Ga area?
I agree...headers are such a critical tuning tool that you want as good a job as possible. Pay for a good,long lasting set just once or pay less FOR less, time and again.... The guys/gals who build 'em professionally are going to give you your monies worth.
Custom headers are not cheap. You may try Tim Murphy at The Fab Shop. He has a deal that he sends to you, you adjust the angles with supplied gauge and tool, clamp them tight and send back for final weld.
Check out the link:
http://www.fabshopheaders.com/adjust...tructions.html
Check out the link:
#13
DYNO OPERATOR
I appreciate all the advice. I was expecting to pay a pretty fair amount for some headers cause I paid $800 a couple of years ago for some for the Vega I had. I thought they would be aroung the same price, not doubled the price now.
Chris
Chris
#14
Chris
Chris
Hey cris sorry just getting back with you been on vacation...you can try the same guy i put you on last time..if i remember correctly he built those headers for your vega while you waited up here that same day.
His name is Craig Owen 864-918-2735
__________________
Bjuice..
"I'M YOUR HUCKLEBERRY ! "
Bjuice..
#15
SENIOR BUILDER
I just went through the same deal. 1500 - 1700 bucks seemed a little high for a set of 2 1/4" small block headers in an altered. I bought a kit from Stahl, pipes are already bent, slip on collectors so I all I had to do is weld it to the flanges. The kit was right at 500 shipped.
#16
A weld up set is not hard to do. Just take you time and do it neat. If you have to tack 'em up a get someone to tig 'em for you. Either way do youself a favor and get 'em ceramic coated. That will make 'em last a lot longer.
#17
DYNO OPERATOR
Thanks Rabbit, I will get them coated. Hey Brian, thanks for the number, they did weld my last pair up while I waited. Maybe I can come up there and see you and the family again
Chris
. Chris
#18
SHOW GUEST
chris im phillip from Hedman The thing is on hedders for your car is the opel has limited room even though it is a chassis car... and you said you have arms as well if it were a strut front end it would be easier to build. yes i understand your shock as you say about th price but when you count in the cost of materials and welding supplies and a person to build you a custon set on your car for a 18degree motor. it adds up! either us or lakepoint tube chassis would build you a custom set for your car that would have sparkplug clearence and a-arm travel and ground clearance as much as possible with it being a very low opel. chris i hope you find someone to do this but it might be a costly job to have done! good luck chris if you need a kit or just a bunch of bends and flanges ,give me a shout! hope this helps later phillip [/i]
#19
Chris, you have another option, other than going under the car, you could put a hole in the back of the front fenders and run a combination of fenderwell type headers, we're seeing more of this type setup in the last couple yrs. on a-arm chassis cars, i have a friend who has Baretta with this type setup. The tubes are about 24" long then the collector.
#20
__________________
Bjuice..
Bjuice..
