Need shaft rocker help!
Old 03-13-2010, 07:22 AM
oldandtired
oldandtired's Avatar
Originally Posted by SC8398
can i just take those out and then reinstall or do i have to losen all and retorque the whole set?
Do one at the time and you will be OK. Dave
oldandtired is offline
Old 03-13-2010, 07:29 AM
SC8398
APPRENTICE
good deal
SC8398 is offline
Old 03-13-2010, 11:02 AM
  #13
SC8398
APPRENTICE
Just one more question, before i noticed they were rubbing while turning the motor over a couple of the rockers were gouged a little on the bottom corner edge. I did clean them up so that no more shavings were on them but i was just wondering how safe i would be running these. I'm not running alot of spring pressure, ( less than 600) but i'd just like another opinion.
SC8398 is offline
Old 03-13-2010, 03:15 PM
  #14
TheEngineer
TheEngineer's Avatar
Ouch!!! I'm not exactly sure where they are rubbing from your explination. Is the rocker hitting the edge of the retainer? If so on Jesel shaft rockers, your installed shaft height (rocker geometery) must not be correct.
WD
TheEngineer is offline
Old 03-13-2010, 03:28 PM
  #15
SC8398
APPRENTICE
No they are yella terra rockers and they were hitting on the outside corner, ( number one exhaust rocker) and so on on that side. it was on the outside corner nearest the stud and less than 1/32 was shaved off, really just the corner radius.
SC8398 is offline
Old 03-13-2010, 04:38 PM
  #16
blowninjected540
EXPERT BUILDER
Order a set of T&D last thursday, I will be looking out for that. Thanks
blowninjected540 is offline
Old 03-14-2010, 07:18 AM
  #17
SC8398
APPRENTICE
any opinions?
SC8398 is offline
Old 03-14-2010, 03:45 PM
  #18
SC8398
APPRENTICE
I smoothed out the rockers where they had hit and they look to be ok, i cut the studs and all of the clearances are good. With no more pressure on the rockers we're going to give it a shot and keep an eye on them and see what happens
SC8398 is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
