fuel pressure guestion
Old 01-15-2010, 07:21 AM
itsabird
who's regulator, are you useing?
itsabird is offline
Old 01-16-2010, 03:34 PM
andybyrd
Thanks Curtis and everyone else, you were right it turnsd out being the regulater, I put a new one on and it works perfect now. I set it at 8 and it stays at 8 I know for 5000 rpms for sure now, but man what is it with the 280 leaking. I bought a rebuilt one through Jegs and it leaks about 1/2 teaspoon overnight the 280 thats been on there for 3 years never leaked a drop. I think I'm gonna have BG rebuild the old one and sell it and buy me a Magnafuel 300 and try them. this first BG has been a good one though I just wanted to rebuild it for a spare.
Thanks Guys Andy
andybyrd is offline
Old 01-16-2010, 07:55 PM
  #13
markdunlap
DYNO OPERATOR
Default Feul pessure problem
What about the Aeromotive A2000 electric fuel pump?
Rated at 350 GPH
They say it needs a 100 micron filter before pump and a 10 micron filter after pump.
They rate it to power any application gas or alcohol.
Low amperage draw too.
Anyone have experience with it?
markdunlap is offline
Old 02-01-2010, 12:53 PM
  #14
rick329c
SHOW GUEST
Default Fuel Pump
Andy,
All the advice I see looks right on! I had two BG 400's in a row do the same thing to me. Put a Magna Fuel on it and never had another problem.
The QuickStar 300 from Magna fuel would be just the trick for your combo.
Sorry I don't have any experience with Aeromotive!
rick329c is offline
Old 02-05-2010, 06:26 PM
  #15
dynaguy03
Default Aeromotive A2000
I have used the aeromotive on a SBC/S10- making @700hp .. I used it on both Gasoline and alcohol. It worked well on both. Although .. i set it up exactly as Aeromotive suggests.. line sizes.there regulator..filters ect...
On alcohol i belive it was at its max. I started at 9lbs at idle at was 7 thru the traps.
On Gasoline the pressure never moved ..and this pump filled a gallon jug after the regulator at 15 seconds - some serious flow IMO.
I have used there products on gasoline and feel they are outstanding - if u have tech questions - they have great service.
Since, i have moved to a dragster...with a belt driven pump..but i had great experiance with Aeromotive A2000 pump.. if you follow the proper setup ..line sizes -regulator-you will get great results.
Keith
dynaguy03 is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
