how tight for roller cam button bbc
Old 01-12-2010, 05:12 PM
zipper06
Watch out for gasket thickness, i've seen gaskets as thick as .030 and some as thin as .010. I just measured one gasket that was .027 thick and another that was .013 tk.
That is if you're running a gasket
Also don't use a stock thin sheet metal cover that will flex.
zipper06 is offline
Old 01-13-2010, 03:12 AM
ejm
SENIOR BUILDER
my cover has an adjuster on the out side. can i go with that and check endplay
ejm is offline
Old 01-13-2010, 05:18 PM
  #13
zipper06
That makes it real easy then, all you have to do is determine how many threads per 1" is on the adjuster. Example if it's 5/16"X 24 Divide 24 into 1.000 and that will tell you how much to back the adjuster out once you adjust it to "0" against the button. Example 24 would be .041, so you would back it out 1/8 of a turn for .005 clearance.
hope this helps.
zipper06 is offline
Old 01-15-2010, 03:44 PM
  #14
ejm
SENIOR BUILDER
thanx zip thats what i was looking for !!!!!!!!!!!!!!!!
ejm is offline
Old 01-15-2010, 07:33 PM
  #15
zipper06
Welcome,
zipper06 is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
