SBC AC oil filter collapsed
Old 01-03-2010, 08:51 AM
krazy55ken
APPRENTICE
Its allways been k&n or wix for me,,
krazy55ken is offline
Old 01-03-2010, 09:36 AM
rob41willys
SENIOR BUILDER
I use the wix racing filter
rob41willys is offline
Old 01-03-2010, 09:39 AM
  #13
cartwright454
JOURNEYMAN
Originally Posted by TheEngineer
I think the key factor here, is that most of the race filters have a "much thicker" canister side wall thickness. Whereas, a standard filter (non-race) has a very thin canister. The internal filter element, is another issue.
Warren
The cansiter looked new. the filter element must have collapsed.
cartwright454 is offline
Old 01-03-2010, 09:46 AM
  #14
rob41willys
SENIOR BUILDER
I always cut open the filters to see whats in them. you can catch a problem before it gets real bad. But I change them often though. You need to use a real filter cutter though so you don't have a bunch of metal filling from cutting it open
Old 01-04-2010, 06:50 PM
  #15
jaxsmith
Member
MASTER JOURNEYMAN
Fram racing filters are nothing like their conventional filters. They don't pay me and there are other brands like NAPA and WIX "racing" filters that could be used. Bottom line is buy a heavy duty filter to match your engine. If your race engine does not turn more than 4500 rpm and has a standard oil pump you would never have a problem with a "standard" filter. My engines put out around twice the pressure of a stock engine and by the pump selection put out more volume than stock. I have never had a problem with a race filter. Go buy one of the good filters and cut it apart.
jaxsmith is offline
Old 01-05-2010, 02:47 AM
  #16
gnsrule
SENIOR BUILDER
Originally Posted by cartwright454
So I will ditch the hastings and go with a wix. thanks
Nobody said anything bad about a Hastings.
Myself, I run a Baldwin. After seeing one cut open its a no brainer.
Craig
gnsrule is offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
