468 bbc lay over
#15
You're running a front mounted tank,(right), also is the line feeding the pump at least a #10, also is the pump mounted below or level with the bottom of the tank. I had a friend who had the pump mounted too high, and on one run he forgot to refil the tank between rounds, luckly the other guy redlite, and my friend ran 4 ths slow, pulled plugs checked everything, not popping or anything. Then he slapped himself in the head, filled the tank and went right nack to the previous #'s. He's since remounted the pump below the bottom of the tank.
Just a thought
Just a thought
#16
APPRENTICE
lol yeah i have seen that before ...but i have the #10 and i have the pump low ...i have a toilet on my other car also ..it runs and wins great leading the 7.0 points right now...but this other car is well i have no idea any more
#17
O'K partner, i was just checking, very well could be MSD problem, i had a new 2 step that was bad once , and the car sat on the line and jumped up and down on the trans brake without breaking the beams, i have a vid of it but i'm too embassased to post it, took 3 trips to the track before i figured it out. I'm the opitidy of stupidity, and now i have a spare of everything, but i might not be able to figure it out in time to race the same nite. O'h by the way do run a 4.1 toilet bowl so i am familar with them.
#20
APPRENTICE
was it doing something in high gear? i know low gear it will lock up the tires..i have forgot to put my car in low after the burn out and hit the transbrake just to fly out of the lights ...that suck lol ...thanks for the info im going to check it tomorrow ...im putting on a race here ...my first one out of my pocket just hoping people show
"BEST OF THE BEST " race
