pro/sportman brake red light green light
SENIOR BUILDER
Originally Posted by johnracer
an additional hole is usually drilled in the rear of the case for a pro brake. I'm not sure if you'll have to plug it
I have spare unmodified cases so that’s not a big deal
SENIOR BUILDER
Originally Posted by shawnp
you need to adjust front tire psi, size
I have the tallest that will fit m/t sportsmen radials on front now not a lot of sidewall give in them
Had a set of e/t drag front before very adjustable sidewall still not enough
#14
SENIOR BUILDER
Originally Posted by onedragracer
You might try one of the slow releasing transbrake switches from Biondo.
That might help you.
Hence the? About reaction difference going to a sportsman brake I feel and I may be wrong it's the more consistent answer to my problem
#19
SHOW GUEST
I have the same problem in my FED with a pro brake. I was told that pro brakes react around .4 and bracket brakes around .5 which would be perfect for me since I am about -.105 at the first sight of third yellow.
This may sound stupid, but heard of Alan Johnson doing it to get around the rev limiters in top fuel when they came out. He ran an extensive amount of wire to lengthen out the time it took to travel from the rev limiter to the ignition. I have thought of taking a 25' coil of wire and splicing it between the button and the trans brake/two step. Any electrical guys thing that would work. Could you use lengths of wire to tune your reactions times. I don't believe it is against the rules. :roll:
#20
Sure that'll work, but electricty travels at the speed of light, so 18600 ft of wire should equal a tenth of a second. there is no rule against haveing that much wire in your car, but where will you set :P 25 ft, will make no difference.
