Water wetter, does it work?
Old 04-14-2009, 03:51 PM
cartwright454
JOURNEYMAN
Default I was told to use laundry liquid softner
I have been told it takes the air bubbles out of the system and laundry liquid softner does the same thing?
cartwright454 is offline
Old 04-14-2009, 04:23 PM
Scooterz
Well, I tried it in a 2-stroke (KX250) that was getting hot on a 33mi annual poker run I used to do. The year I tried it (2003) it made a difference. All I know is that it did not over flow like w/o the water-wetter. In a race car, I do not have the expierence though. Scooter
Scooterz is offline
Old 07-29-2009, 12:18 PM
  #13
mopar1962
Member
JUNIOR BUILDER
not allowed on the track here, blow a hose or freeze plug going down the track and its slipsville...
mopar1962 is offline
Old 07-29-2009, 12:22 PM
  #14
ssym
Member
JUNIOR BUILDER
I bought into the anti corrosion and water pump lubrication properties as well.
I run distilled water and water wetter. Don't know if it runs any cooler.
ssym is offline
Old 07-29-2009, 12:53 PM
  #15
TheRabbit
TheRabbit's Avatar
I run it in everything I own. Does it work? hmmmmm... I really dont' know. I guess I got it just in case it does. ops:
All kidding aside we use to put it in warehouse forklifts that were running hot. It did cool them down and good bit. Probably 10-15* like other guys said.
TheRabbit is offline
Old 07-29-2009, 02:27 PM
  #16
ARUSSELL
I found Purple Ice from Roaya Purple works better
ARUSSELL is offline
Old 07-29-2009, 02:33 PM
  #17
whitey70ss
DOESENT DISH SOAP HAVE FOAMING AGENTS??? :shock: JUST A THOUGHT?!
whitey70ss is offline
Old 07-29-2009, 07:58 PM
  #18
RICK80
SHOW GUEST
Default water wetter
I used "Below 40" in my mini sprints and full sprint car. Never ran a fan on the radiator, only air flow is when we were moving. Liked the way it ran the temp down. Worked quite a bit better than the "WATER WETTER". You run it with distilled water and a slight amount of anti-freeze.
RICK80 is offline
Old 07-29-2009, 08:13 PM
  #19
kwkracing
It does not work if you are making any power with a non adaquate cooling system, Dont waste your money, fix the problem
kwkracing is offline
Old 08-04-2009, 06:01 AM
  #20
TheYellaBrick
TheYellaBrick's Avatar
Agreed. ANY coolant cooler additive is no solution for an inadequetly effective SYSTEM. It's only a 'fine tune'.
TheYellaBrick is offline
