Blower size and amount of boost.
I personally think the old hilborn 2 port injections would be plenty and would look better on your setup. If you watch ebay motors hilborn injections you'll see one turn up ocasionally and very reasonably, like $500.00/$600.00, i ran both the 2 port and 4 port, with small inch motors yrs. ago and the 2 port out performed the 4 port.
SHOW GUEST
I think your right zip. I kinda had that in the back of my mind. its a little motor and the bug has 3 - 3" right? Ive been worried it might be a bit much. 2-3" might work better. I haven't talked to any injection guys yet about this set up. I've got a lot of work ahead. Hell, I still need to build a car to put it in.
Thanks all.
Thanks all.
#13
I have always had to block off one the the holes on a bug when using for similar set up. It is pretty simple to install a block off plate.
Either way a hilborn or enderly will give you a bad ass look sporting a blower.
