Spring rate suggestions
DYNO OPERATOR
Originally Posted by triniemi
I measured the current springs (at our gym
). The spring took 400lbs to compress it one inch. Way too tight? Free lenght is 7" and they were installed at 6". I'm considering to order the 7" free lenght 300lbs springs. Can I now calculate how much I should preload the 300lbs springs to achive the same ride heigh?
). The spring took 400lbs to compress it one inch. Way too tight? Free lenght is 7" and they were installed at 6". I'm considering to order the 7" free lenght 300lbs springs. Can I now calculate how much I should preload the 300lbs springs to achive the same ride heigh?Sorry I can not give a more pointed answer with the info available, but you should be in good shape from here wont you?
Good luck in 09
Member
JUNIOR BUILDER
There is about 1.5" of shock ram showing when the car is at the ride height with the current 400lbs springs. I could drop the nose a little, but not more than 0.3" or the headers will touch the ground. Do I need to get taller front tires if I want to drop it more with new 300lbs springs or is there another way to get the shock ram showing only 0.75 inch?
#13
DYNO OPERATOR
I just had this notion to ask you, The engine weight is in the car when you are checking this isn't it?
#14
It depends on how much total travel the strut has. Most racing struts only have a total of 1 1/2" of travel from fully extended to the snubber. If that's the case with your struts with 1 1/2" showing now your strut is "topped out" or close to it. It might be that someone has tried to raise the car from the ride height it was built for which is a difficult thing to do with a strut car. If there is no extension left in the struts with the car at it's desired ride height you will need to either lower the car, use a bigger tire or change the strut mount.
I would recommend using the hypercoil spring. They're a much better spring than the springs you linked to. They're a little more expensive but worth it. You can buy them from strange. I noticed the springs you linked to are priced each so double the price they have there.
#15
Member
JUNIOR BUILDER
