weld it or replace it?
DYNO OPERATOR
Originally Posted by zipper06
What's your problem you've had 5 years to fix it? :lol:
I hope I did not give to up to date of information :lol: :lol: :lol: :lol: :lol:
Little humor, very little humor :roll:
What's you problem you've had 5 years to fix it? :lol:
#13
But since the fun is over, i will answer your question, put a bell on it, don't even try to weld it.
#16
DYNO OPERATOR
The flywheel diameter is not a problem with the ultra bell unless you are making your own larger than stock diameters? They look a lot smaller than stock but the register in the front is machined for a stock diameter flex plate and it does come very close to the bell and may look too small prior to fit up.
the torque converter however, has to be smaller than 13" or so but that never usually comes into play on race applications.
#19
From a Rod & Custom article;
The hemi UltraBell can be ordered to fit a TH350, TH400, or Powerglide. What you have to do next sounds like a "radical bell-ectomy" but taking off the stock bellhousing from your transmission shouldn't scare you. Complete details and measurements are included with the UltraBell kit, and the deed can be done with a Bridgeport, reciprocating saw or an air tool with a cutoff wheel. The bulk of the housing is taken off on the first pass, leaving a small amount for a die grinder to finish off for a nice, clean edge. The cut doesn't have to be perfect (just don't let the blade wander into the pan rail or top of the front pump).
You can mask off the front pump and input shaft with duct tape and plastic during this procedure, but there's no need to disassemble the whole enchilada. Once you've done the obligatory post-op cleanup, you can remove the front pump bolts, push the UltraBell over your trans, and bolt it down using the high-strength Allen bolts supplied.
#20
Member
MASTER JOURNEYMAN
