ProCharger Engine must have's
#13
Originally Posted by bjuice
if you gonna spend some Money and by the looks of it ..you are ..
why not toy with the Turbo idea ?
don't know what your trying to build..but a 6lb street strip /style turbo will make a bunch more HP on an engine then 6lbs of Blower..a Big reason is No belt drag on crank.
i got a 406 ci in a 69 camaro i have plans for a turbo in the future,,just trying to decide if i want to go twin turbo or single ?
#14
jreiley
The first thing you do is pray!!!!!!!!!!!
Give me a run down on your engine combo, type of car, weight, tranny, gears & Type of carbs.
A big problem with blowers is the inability to supply the correct amount of makeup air even when running dual 4's. A lot of set ups I have seen built by others seem to smoother or choke the engines ability to produce power even on low boost.
