using engine lift plate, bolted to intake, to lift engine
Member
JUNIOR BUILDER
I use a strap through the valley under the carb pad. Like one of those axle straps. Need one long enough. I've used that for years on my BBC even with sheetmetal intakes. With all acc. on the front of the motor its a perfect balance.
#14
engine leveler for me...i had a speacial plate made to cover exhaust port on both sides of the head...Plus this hoist set up is a must for blower and tunnel ram engines.
__________________
Bjuice..
"I'M YOUR HUCKLEBERRY ! "
Bjuice..
#16
Personally I'd never use one even though I've seen people put allot of weight on them but it would be my luck that the one time it failed it would be on me.
I built a load leveler and use grade 8 3/8 bolts, bolted directly to the back and front of the heads, using the intake bolt holes is another no-no in my book too.
JMO, Charles
JMO, Charles
