NEW DART SHP BLOCK (PICS)
Originally Posted by hink
Originally Posted by zipper06
Hey Carl,
Just curious, what do you do with the lifter bores if they are good to specs? do you give them a little more clearance, and leave them as they are or do you bush them and put them dead on. Also i saw the block in the pics. Does it have cast iron mains or cast steel mains like the dart little "M" blks. Just curious, because i bought a little "M" block that had cast iron caps.
zip.
zip.
We bore gauge all the lifter bores to make sure they are not to to tight.
Those caps are nodular iron caps and are one and half times stronger thenthe a standard GM grey cast cap. It is the same cap as far as material as the Little-M Sportsman block
EXPERT BUILDER
Hey Carl,
zip.
zip.
#14
Hey Zip when you bringing that bad boy Anglia w/ that blown 434 to Byhalia?
I'm sure Mike Frank ( track promoter ) could set you up a match race with someone.
Here's a link to the tracks webpage. http://byhaliaraceway.com/
They are having a benefit's race this weekend for ST Jude's Childrens research hosiptal, lots of stuff to raffle off plus a cake walk and a best 2 outta 3 match race with Russel Synder's altered ( 4.90's ets ) VS Steve gurley's digger plus the regular bracket program.
It should be a hoot!
Later Cp
Later Cp
