1/2 or 5/8 rear wheel studs
Originally Posted by lively
???--DO YOU HAVE TO DRILL OUT YOUR ALUMINUM RIMS BIGGER OR IS THE LUG NUT SHANK JUST THINNER???
Member
JUNIOR BUILDER
Originally Posted by suicidebomb
They can be drilled.
Return & Shipping and labor was around 100 $
#13
Mine are mosers too, we drilled them on a bridgeport, but I don*t remember using any special drill. But we may have, we did it about 4 years ago in a friend of mines machine shop, if he can remember i*ll find out and post here.
#15
i don,t think, that section of the axel is as hard as the shaft, so it would be drillable if thats a fact, but it will have to be taped for screw in studs, i don,t know of any press fit 5/8 studs. it might be less of a pain to send them out.
#16
Guys, I dont remember them being hard to drill at all. I did the drilling after he helped me set up the mill, and we tapped the holes for screw in studs. I*M still trying to get a hold of him, when I do I*ll let you know.
#17
It took me awhile to run him down, but I finally found him. For that I apologize. HE said that we used a titanium nitride bit. he said it was very sharp, and he said we drowned it in oil. run the bit at 175 RPM. Anyhow, thats how he said we did it. I think we did the whole thing, all 10 holes in less than an hour including setting up the mill. We used the mill to tap the holes also.
#18
I'd be more concerned with the tapping than the drilling....if you get ONE hole started crooked your stud will poke out all crazy and you WON'T be able to get your wheels on...or have another chance to fix it
ops: I believe in doing everything you can yourself,but unless you have the proper machines...leave it to the pros.That's just my $.02
#19
Eric,
It's not that hard to get a tap started straight, just get a piece of material as thick as the threads on the tap are long, drill it so the tap just fits through it. Clamp it to the flange in line with the hole, you have your guide that way. Easy and straight. Of course the best way is just use the mill to do it, no problem if you have access to a mill. I just through it up on my HMC and push the button.
Curtis
Curtis
