pcv or evac:which is better for drawing vaccum?
Old 01-25-2008, 11:11 PM
cepx111
If your really crafty you can go to your local bone yard, fab up some brackets to mount a old smog pump and use the suction side as a low buck vacuum pump. Works good and I've seen many used like that especially at my hometown redneck track here in north missisppippi, I've always used the header evac set up for my cars and I've never had any problems with them personally and I dont see why you should be able to use just one side of the engine if one of your collectors is tied up with a ego sensor. I've also seen then use old blower motor fan motors as water pump drives, I'm just a little more picky about how my stuff looks but hey if it works use it. ><Cp
cepx111 is offline
Old 01-26-2008, 07:27 AM
GLADIATORINC
Member
CRAFTSMAN
If your only racing, WOT is the only thing a race engine sees. The basic valve cover to collector evac is excellent. The issue comes up when you stray from the track and go for a cruise on regular civilian roads. Even if for a couple of miles , the evac then isn't working at 100% between idle and WOT. that is where the mech pump's all time presence helps from fouling sparkplugs and causes gaskets to weaken and leak. I am really interested in hearing if anyone runs an electric version. I will message the guy on RJ that is selling them to see if he will give us some feedback.
GLADIATORINC is offline
Old 01-26-2008, 09:54 AM
  #13
hammertime
Originally Posted by caprice327
:idea: So when is someone going to step up to the plate and get a patent on a AFFORDABLE electric or belt drive evac pump for the high performance street guys and become a multi millionaire?
I would do it but I dont have the funds to get it started
they have GZ Motorsports makes a affordable belt drive set up. I would run without a vacuum pump anymore, very good investment
hammertime is offline
Old 02-06-2008, 09:01 AM
  #14
caprice327
APPRENTICE
I was thinking more affordable as in $150 for 12" of vac.
I ended up purchasing 2 of the Mr gasket kits
and modifying the 4 tubes with venturi holes to make better use of the exaust pulses. Im going to weld a 1/2" long piece of 3/8 tube over the venturi holes to help capture/accelerate more energy.
Whenever this happens I will hook up a vac/boost guage to the crankcase and post some video results of it in action[/img]
caprice327 is offline
Old 02-07-2008, 03:51 PM
  #15
olds48
Where would I put the backfire valves on my car?My collectors are 10" long,then there is a 24" straight pipe and ends at a turndown?No muffler.Would it still go in the collector,or towards the end of the entire works?
olds48 is offline
Old 02-10-2008, 02:12 PM
  #16
superstreeter
SENIOR BUILDER
well I`ve been using an elec GM air pump (vac pump) with a voltage reducer to keep it running cooler,,pulls lots of vacuum, and I run the system open with a lite restriction on the intake end,,pulls way more than the header style evac,,,maybe 10 times more,,and you can mount the pump were ever you want,,only draw back is you need a good separator tank,,I use it mostly just for the track,,,and it works great,,,,pulls as much vac as my bros aerospace one,,and at least 1/2 the cost
superstreeter is offline
Old 02-13-2008, 07:00 PM
  #17
GLADIATORINC
Member
CRAFTSMAN
Sweet, I needed to hear from someone who uses the electric version. I just bought Borla header collectors which don't have the fitting and I am not tearing them up, so I have to run a vac pump. If I can't find a good deal on a mech I am definately using electric.
Thanks superstreeter.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
