ok simple question to be answered
#13
JOURNEYMAN
To some degree torque is the grunt that gets things moving, and horsepower is the force that keeps things moving.
On modern day dynamometers horsepower is a calculated value. It's important to remember the dyno measures torque and rpm and then from these calculates horsepower. On the dyno it takes more water flow to the water brake to increase the load on the engine being tested. As the test engine's torque rises more water flow is needed. As the test engine's torque drops less water flow is needed. The dyno's water brake does not respond to Horsepower. Major adjustments to water flow are needed as an engine crosses its torque peak but none are needed as it crosses its horsepower peak. In other words the water flow to the brake during a dyno test follows the engines torque curve and not its horsepower curve. Torque is what twists the tire, prop, or pump. Horsepower helps us understand an amount or quantity of torque. (Torque + time and distance)
#14
I always heard that horsepower doesn't actually exist.That it's a measurement of torque over a period of time.I also have been told that 1 hp is the amount of energy required to lift 600lbs straight up one foot.If it can go 1 foot why not 2? don't make sense to me.TAKE HIM FOR A RIDE,THAT'LL CLEAR IT UP
#16
Originally Posted by rabiddawg
I tried to explain to this ricer kid at work about torque and horsepower he dont get it.
he is stuck in his idea that horsepower gets a car moving and is the sole force required?
I tried to explain as simple as possible til I was blue in the face but I gave up.
ok anyway to explain these two forces in real easy terms and the relation between the two ?
(gotta keep it simple so a ricer can understand)
Maybe he might get it.
