Methanol Exhaust Temp
#15
APPRENTICE
Can't see what else you want to know. 2004 4 link worhy mono shock, 33x 16 tires, 4.10 gear, 9 inch coan converter, 632 inch. bodia 2x heads - ported, 14.7 comp, 1250 BLP carb, Blp fuel pump, hughespower glide, 35 degrees timing, shifting 6800, launch at 4800, 140 mph in 1/8, 4.85, fuel pressure at the pump holds about 10 psi, just trying what the egt should be to maximize tuning.
#16
1050-1100 in the 1/8th you'll be close.
You need different heads and that combo would fly!! even with them heads it should be a good tenth faster you are leaving some on the table. Conv will be my guess.
