Main bearings small block chevy,rocket block
Old 06-03-2007, 05:33 PM
davis419b
EXPERT BUILDER
Hey Mike, mine was a dry sump also, if you are trying to keep the excess oil out of the engine i dont think the drian holes in the lifter valley would be the problem. I think part of my problem was it had 16-1 compression and a 4.250 stoke. When my engine builder built it he had never built a SBC with a 4.250 stroke and wasnt sure it wouldnt try to throw the the rods right out of the block. The only problem i ever had was main bearings and im not sure it wasnt the rocket block. I had a freind with a 454 with a 4.125 stroke in a dart block with no problems and he is still running it after 5 years.
davis419b is offline
Old 06-04-2007, 06:12 AM
billhendren
Originally Posted by topdragster5051
My block is a dry sump
Do you have a suction line from the lifter valley? if not you will fill it up with oil.We have built many engines using this block with no problems. Bill
billhendren is offline
Old 06-04-2007, 10:27 AM
  #13
topdragster5051
SHOW GUEST
Yes one line in lifter galley & 3 on oil pan. What clearance do you run on the main bearings?
topdragster5051 is offline
Old 06-04-2007, 05:28 PM
  #14
billhendren
We use .003/.0032 with .0025 / .0028 on the rods.most drag racers don't get the oil temp up high enough before making a run and cold oil doesn't flow very well,this problem is worse in a dry sump engine where the oil isn't in the engine very long. you need light weight oil and a heater on your dry sump tank to get the oil above 160 deg before making a run,we use Gibbs XP3 which is a full synthetic 10/30 weight in normally aspirated engines and XP6 in the blown, turbo and heavy N20 engines. its 15/50 Bill
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
