-   -   PLEASE I am in need!!!! part 2 (https://www.racingjunk.com/forums/showthread.php?t=32284)
TheYellaBrick 07-05-2012 06:39 PM
:D :D :D Couldn't resist that kids.....
I own a 1997 Honda accord wagon that I use as one of my service rigs....I know, I know, ricer, BOOOOOOOOooooooooo............
Any way I had this unnatural noise coming from under the timing belt area. Had to make a specialized tool for holding the crank pulley still while I broke loose the crank bolt(190 ft lbs). I got everything exposed, it's not the belt tensioner, water pump, or balance shaft making that rattle, shrieking noise, but a separate pulley thing-a-ma jig on the firewall side. For the life of me I cannot see what the heck it IS or drives.
Here's my NEED; I cannot find ANYwhere online a blow up diagram of the front of this engine. Haynes manual is garbage, gives you enough info to get into serious trouble. No one in this small town USA has anything on it.
It is NOT the Vortec engine but is the regular 2.2 4 banger.
Anyone steer me in any direction besides crazy ?
:shock: :shock:
mopar1968 07-05-2012 06:42 PM
Can you take a picture of it and post on here :?: :?:
Check this out Double-D Is this what your talking about :?:
http://www.youtube.com/watch?v=r08PToVy4f0
Mark
MEMRACING62 07-05-2012 06:49 PM
TheYellaBrick 07-05-2012 07:02 PM
Bottom looking up;
http://i233.photobucket.com/albums/e.../IMG_0986b.jpg
fast75vega 07-05-2012 07:08 PM
i believe that is your oil pump drive gear .... :wink:
i can double check on all data for ya too
TheYellaBrick 07-05-2012 07:12 PM
whatever it is, I gotta figure out how to get to it. :shock: :shock: :shock: :shock: :shock: Thanks for the help guys...
mopar1968 07-05-2012 07:15 PM
Ok Double-D according to this video it is a Balance shaft assy :!: :!:
http://www.youtube.com/watch?v=yQ6x_...eature=related
Mark
fast75vega 07-05-2012 07:22 PM
get to it? is it bad....? you need to pull all the pullys off and drop the pan... then the front cover will unbolt
TheYellaBrick 07-05-2012 07:46 PM
Yes, it's bad. As this is an interference engine, if whatever it is freezes up, I could lose a bunch of valves. If it's the oil pump I might already have a major issue. I need pictures/diagrams so I can see what I'm dealing with. Like in the old Motors manuals.
Mark, that Eric the car guy has quite a website !
mopar1968 07-05-2012 07:53 PM
Double-D look at this i believe your right it is the oil pump :!:
http://www.familycar.com/autoparts/h.../oil_pump.html
Mark
