-   -   1970+ Camaro Nose Conversion to 1970 Nose (https://www.racingjunk.com/forums/showthread.php?t=29102)
ProStreetLuvr427 10-26-2010 08:54 AM
I saw in Chevy High Performance one of 2010s issues a 1977 Camaro with a 1970 nose.
How would you do this?
Is this a simple fiberglass 2 piece conversion?
tattooman428 12-15-2010 12:22 AM
i'm pretty sure you can just bolt the whole dog house from a 70 right onto the 77 and about all the lines are the same, i know they use the same hoods and i'm real sure the fenders lines match up with the doors on these yrs
mytmouz 12-15-2010 08:20 AM
The fenders are the same, unless you have the later Z fenders with the scoops, they will fit, just have the scoops. You can bolt the upper and lower cowl piece off the 70 onto the 77, and use the 70 grille, minor fabbing on the header panel for bolting things up is about it...
