blown bbc using dry sump
have a bbc carberator motor that uses a dry sump system.i am converting to blown. how does the belt drive hook up with blower pulley in the way? i was driving the pump with a belt off the end of crank. thanks any suggestions?
One way I have seen it done is to sandwich the dry sump pump between the cam drive hub and the fuel pump. Kinda puts the fuel pump way out there but the one I saw ran like a bat outa' hell! I believe RCD or maybe Waterman makes adapters for this purpose. I can give ya a name of a racer in California who will know....... 8) JB
[img]http://img706.imageshack.us/img706/5...cae91kxrca.jpghttp://img706.imageshack.us/img706/r....jpg/1/w77.png[/img]
here you go,,,available from RCD engineering |
| All times are GMT -8. The time now is 02:51 AM. |
