-   -   sludge in the pan. (https://www.racingjunk.com/forums/showthread.php?t=24809)
andybyrd 07-02-2009 02:32 PM
sludge in the pan.
What causes the sludge build up in the oil pan in a motor with only 50 1/8 mile passes and the oil has been changed after every 10 passes. using valvaline 20w50 racing oil and wix racing filters, Dart little m SBC 434 - 665 HP,
Thanks Andy
kwkracing 07-02-2009 02:42 PM
It could be what ever lubricant, moly,grease... was used when the engine was assembled that did not mix with the oil?
BEAST477 07-02-2009 02:56 PM
x2
andybyrd 07-02-2009 05:18 PM
would it be smart to pull the pan and clean it out. I've been seeing it on my drain screw.
Andy
BEAST477 07-02-2009 05:50 PM
It couldn't hurt. You can look things over and hopfully sleep better afterwards.
zipper06 07-02-2009 08:03 PM
Sludge usually indicates, ring blow by, you might want to do a leak down on the cylinders just in case you have a broken ring.
rob41willys 07-02-2009 09:04 PM
Assembly lube X3
cepx111 07-02-2009 09:52 PM
I'm with Zip on this one.
Any break-in lube should of disolved and been long gone by now, however contaminates such as water and unburned fuels from poor ring seal will build up on the bottom pan and can eventually clog up your oil pump pick-up, you need to pull the pan and clean that gunk out - address the real problem.
Years ago people who added that STP garbage every oil change would have similar problems, seen that stuff 3 inches deep in a pan before.
Cp
MEMRACING62 07-03-2009 03:49 AM
have seen large amount of sludge on engine with a coolant leaking from intake manifold . sludge pluged up filter, pickup, almost took out the engine.
andybyrd 07-03-2009 04:51 AM
Thanks guys, I'm pulling the pan today and cleaning everything out. Can't take the chance, I was just wandering what causes this to happen. I'll also do the leak down test.
Thanks For the Info, Andy Byrd
