electric fan & water pump
What size fan should i use on a full size be cool alum.radiator?
What gpm H2o pump should i use? 500-600 hp sbc 400 motor in a 1986 ss monte carlo that Im just going to race. also is there anyone who will insure a race car? |
elec. fan waterpump
Check w/ grundy antique insurance. also check w/ becool, I think they offer the fan, shourd, you need. Kris
Fit the biggest fan you can. Chuck on a CSR electric water pump. If you're dragging it, set the fan and pump on manual switches so you can run just the pump down the track and turn on the fan afterward. You can also leave the pump running after switching off the motor to cool it down quick.
I agree, biggest fan, highest flow and you cant go wrong.
Spal make very nice fans
just a pointer about buying electric fans..check on the CFM'S of them..i've seen big 17" that only have half CFM'S of say a 15" fan of another brand...the CFM'S is what you want to look for..that is how much air the fan pushes or pulls
| All times are GMT -8. The time now is 01:45 AM. |
