-   -   stang rear set up (https://www.racingjunk.com/forums/showthread.php?t=22857)
twobad1 01-22-2009 07:30 AM
stang rear set up
chevy guy building a 90 mustang drag car 10-11 sec car
w/adj uppers, plates ,etc.wheres a good place to start for best traction?
2deg dn? 0? antiroll any help?9in tire.8.8 430:1
bryanm 02-06-2009 08:20 AM
I set my Mustang up with 2-3 degrees pinion angle and no preload on the anit-roll with the suspension loaded. What other suspension do you have.. shocks, struts, coil-overs??
twobad1 02-08-2009 10:14 AM
lakewood coil overs up front,strait lowers/adj uppers w/factory springs
for now but it does have upper coil over/anti-roll installed for future use
aje-or similar k-frame w/mid-front plate & pg tubular x-member
and yes its tied in w 14pt cage & factory sheetmetal
thanks for the input!
