engine oil dip stick
trying to get a oil dip stick for a 85-96 chevy 350 that is on right side of motor. for a s-10. go to dealer and they need to know what the application is for. got a chrome one from a speed shop and it leaks. any help. thanks
Any should work. I'd just tell them it's for a C1500 to keep it simple....
dip stick
all tubes are two long . all i need is a tube 6-9 inch. long
put silicone around the chrome and put it back in.. :D
tried that. chrome ones are to tight. tried to grind off some chrome with silicone now it leaks. would like to find one from general motors and try it.
On my motor I had to put a o-ring on the shoulder of the dipstick tube where it goes into the pan and then silicon the hell out of it. Now its dry as a popcorn fart down there now.
Cp |
Is it blowing the dipstick out? Or leaking where it goes in the block at the bottom?
just leaking.
Pull out the dipstick and put a freezeplug in the hole. I have a site pulg in the side of my oil pan and with this setup no leaks!!!!!
where do you get a freese plg that small? the hole is 27/64". thanks
| All times are GMT -8. The time now is 07:21 AM. |
